Activity Forums Compression Techniques Duplicated keyframe
  • Duplicated keyframe
    Posted by Alejandro Alves on April 27, 2011 at 9:19 am
    Hello,
    After changing the bitrate of a video with the two pass I get a duplitace keyframe…I get two 0 timestamps…
    The commands that I use is:
    ffmpeg -i $1 -an -pass 1 -passlogfile $2 -vcodec libx264 -vpre slow_firstpass -b 120000 -threads 0 $3 -v 0 2>&1
    ffmpeg -i $1 -acodec libfaac -ab 128k -pass 2 -passlogfile $2 -vcodec libx264 -vpre slow -b 120000 -threads 0 -y $3 -v 0 2>&1
    What could I do to erase this duplicate
    Michael Rampe replied 15 years, 3 months ago 2 Members · 1 Reply
  • Michael Rampe
    May 5, 2011 at 12:33 am
    [alejandro alves] “After changing the bitrate of a video with the two pass I get a duplitace keyframe…I get two 0 timestamps…
    Can you post a sample of the terminal output showing this?
    [alejandro alves] “ffmpeg -i $1 -an -pass 1 -passlogfile $2 -vcodec libx264 -vpre slow_firstpass -b 120000 -threads 0 $3 -v 0 2>&1
    You shouldn’t need the passlogfile when using x264 as it generates one itself. Maybe try to remove this…..
    Michael
