Activity Forums Maxon Cinema 4D duplicated image over texture
  • duplicated image over texture
    Posted by Itay Droblas on September 20, 2019 at 10:47 pm
    Hi!
    Newbie here!
    i made this PNG logo, witch i apply as texture on sphere,
    the thing is C4D duplicates the image all over the texture, and also crops part of it (as seen in the pic)
    how can make it stop?
    https://imgur.com/TrquMsY
    i’m trying to make a mockup of the lipstick from the picture bellow (nevermind the alpha and size settings, i know how to handle them),
    i just need the text to be shown once, and to be able to change it’s size.
    https://imgur.com/5Pkt9Ji
    thanks a lot!
    View post on imgur.com
    Itay Droblas replied 6 years, 11 months ago 3 Members · 4 Replies
  • Sam Treadway
    September 21, 2019 at 2:01 am
    select the texture tag (next to the object in the object manager) and in the attributes, turn “Tile” off.
    https://help.maxon.net/us/#TTEXTURE-ID_TAGPROPERTIES?anchor=TEXTURETAG_TILE
  • Brian Jones
    September 21, 2019 at 4:44 am
    in the Material tag/Tag tab uncheck the Tile option – that’s what’s causing your image to repeat.
    Placement can be done on the lower part of that same tab Offset and Length U/V – or you can use Texture mode to move the texture around.
  • Itay Droblas
    September 21, 2019 at 12:57 pm
    that doesn’t seem to work for me…
    i have 2 problems:
    1. when i start to change the offset settings, the alpha channels turn off
    2. i can’t get to rotate the texture
    what i got left with is this:
    https://imgur.com/mDlgQ57
    iried to rotate the text with a transform layer, but when i change the position/scale/ange settings, the image start to duplicate inside the texture, which the make the “tile” option irelevant:
    https://imgur.com/QEQyxD5
    any other ideas?
  • Itay Droblas
    September 21, 2019 at 1:17 pm
    ok, i manage to get this:
    https://imgur.com/RsRGRdq
    but i still cant make the entire texture to be trasparent,
    also, for some reasome, the line in the middle vanished..
