Activity Forums Avid Media Composer Duplicate Tracks
  • Duplicate Tracks
    Posted by Christian Robinson on December 2, 2020 at 12:03 pm
    While working on a student project out of no where I suddenly had 4 duplicate video tracks. 7, 8, 9 and 10. This did not affect the audio tracks. Each time you add a new track it will create a new track. eg. If you create a new track for V7 it will create V7 twice. And if you continue to add new tracks subsequent tracks are also doubled. Each time you delete a duplicate track it will delete the original track. I merged the 4 tracks into an existing track (track 6). I deleted the duplicate tracks. As long as I do not create a new track MC worked with no issues. What could be the cause or the problem?
    A. The sequence
    B. The Bin
    C. The project
    D. The clips
    Before I could send an email to my professor to let them know about this issue I looked online to see if anyone else had the same issue. I found someone in 2015 on this forum who had the same issue. Her solution was finally to create a new project, then create a new sequence. She said in a different view she could still see the duplicate track. She was using an older version of MC. I still see the duplicate after creating a new Project, A new Sequence and I even created new Bins. Nothing that I do will prevent a duplicate track. No other bin or sequence has this issue. I opened up 2 other projects and did not have this issue. The only thing that I could conclude is that one of the “clips” or “edits” within the sequence is cause the tracks to duplicate.
    A way to find out which clip is causing the issue is to deconstruct the project by deleting each clip one by one and testing to see which one is causing the duplication. I dont have that type of time because this is finals week.
    Again, other than NEW tracks being duplicated there is NO other issues that I can see. This is very annoying not knowing what caused this and what the solution is.
    I have tried everything from copying the bins into a new project, creating new bins, new sequences etc. Each time I try to create a new track it will make an additional mirrored or duplicate track.
    Christian Robinson replied 5 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
  • Pat Horridge
    December 2, 2020 at 12:20 pm
    Try creating new user settings.
    If that doesn’t work make a new project and Copt the bins over.
  • Roy Gilbert
    December 2, 2020 at 12:24 pm
    I had the same problem a few weeks ago. I can’t remember exactly how I fixed it – but it was to do with the user settings – specifically the sequence view preset.
    You know how you can save your sequence view by clicking on the on the little arrow to the bottom left of the timeline window? I think these saves views can get corrupted. Make a new one (timeline hamburger menu / default setup) – and I think the problem will be sorted.
  • Christian Robinson
    December 2, 2020 at 3:05 pm
    So your solution is to repeat what Ive already did? you didnt read the original message. I did all of the obvious things before I posted. thanks.
    December 2, 2020 at 3:07 pm
    Im sorry, I mentioned that I had already did this in the email to my professor not in the post. I did all of the obvious things before posting…. Thank you.
    December 2, 2020 at 3:13 pm
    can you provide a screen shot. I have no idea what a hamburger menu is…
    December 2, 2020 at 3:17 pm
    I created new user settings that was a very obvious possible issue… I started an entirely new project. Bringing over corrupt views or sequences will get the same result.
    Ive created new bins, new sequence, new timeline… copying the same clips give me the same results… keep in mind no other project, bin, timeline is effected. So its something unique to this sequence or “view”
    Its either the issue that is being mentioned about some view or settings but I have no idea what a hamburger menu is… I know what a drop down menu is…. but I need more details on what view is being mentioned.
    December 2, 2020 at 3:24 pm
    SOLVED – Roy Gilbert may have assisted on this…. It was the “FAST MENU” I reset it to “Default” it brought in the D1 and the Time-code tracks… basically just resetting the track view. Somehow the Sequence got corrupted. That was very strange. I would have never thought to do that. thank you for all of your help.
