Activity Forums Adobe After Effects Expressions Duplicate the “Stroke” in any Vector Group via Scripting
  • Duplicate the “Stroke” in any Vector Group via Scripting
    Posted by Vincenzo Imbimbo on September 6, 2022 at 10:01 am
    Hello Guys, i’m trying to duplicate the “Stroke” in every vector group of all shape layers selected, but it’s not working, i don’t know what i’m doing wrong, this is the code:
    app.beginUndoGroup("myScript");
    var myLayers = comp.selectedLayers;
    for (var i = 0; i < myLayers.length; i++){
    tryStroke(myLayers[i].property("ADBE Root Vectors Group"))
    function tryStroke(prop) {
    for (var j = 1; j <= prop.numProperties; j++){
    var subProp = prop.property(j);
    if (subProp.numProperties) {
    tryStroke(subProp)
    } else {
    if (subProp.matchName == "ADBE Vector Graphic - Stroke") {
    subProp.app.executeCommand(2080);
    app.endUndoGroup();
    Vincenzo Imbimbo replied 4 years ago 2 Members · 7 Replies
  • 7 Replies
  • Andrei Popa
    September 6, 2022 at 5:00 pm
    This should work
    for (var i = 0; i < myLayers.length; i++) {
    for (var j = 1; j <= prop.numProperties; j++) {
    tryStroke(subProp)
    } else {
    subProp.duplicate();
    app.endUndoGroup();
  • Vincenzo Imbimbo
    September 7, 2022 at 8:30 am
    Hello Andrei, thanks for your reply, unfortunately i’m still getting the same result (nothing happens), i don’t know if there’s a different approach to this, i want to duplicate the stroke of any selected layer (for every vector group) and then change the color of each stroke (assign 1 color to stroke 1 and another color to stroke 2).
  • Andrei Popa
    September 7, 2022 at 11:01 am
    Hey. Sorry, I did not test the code. Here is a working version. I changed the second for, because it was going infinite loop
    var myLayers = app.project.activeItem.selectedLayers;
    for (var j = prop.numProperties; j >= 1; j--) {
    $.writeln(subProp.name)
    tryStroke(subProp)
    app.endUndoGroup();
  • Vincenzo Imbimbo
    September 7, 2022 at 11:35 am
    Thank you! This works perfectly, but is there any way to just duplicate it one time? I don’t want to duplicate everytime i press the button, something like “if this layer has Vector Groups with Stroke 1 and Stroke 2 then DON’T duplicate strokes”?
  • Vincenzo Imbimbo
    September 7, 2022 at 12:07 pm
    Also, i’m trying to change the colors but i can’t figure it out how to access to “Stroke 1” and “Stroke 2”, i tried this:
    if (subProp.matchName == “ADBE Vector Graphic – Stroke”) {
    subProp.content(“Stroke 1”).color.setValue([0,0,0]);
    subProp.content(“Stroke 2”).color.setValue([1,1,1]);
    But is not working 🙁
  • Andrei Popa
    September 8, 2022 at 8:41 am
    This should work
    tryStroke(subProp)
    if (subProp.matchName == "ADBE Vector Graphic - Stroke" && !subProp.parentProperty("Stroke 2")) {
    subProp("ADBE Vector Stroke Color").setValue([0, 0, 0]);
    var str2 = subProp.duplicate();
    str2("ADBE Vector Stroke Color").setValue([1, 1, 1]);
    app.endUndoGroup();
  • Vincenzo Imbimbo
    September 8, 2022 at 4:46 pm
    Thank you Andrei!! That is exactly what i need it, you are the best!
