Activity › Forums › Adobe Photoshop › Duplicate Smart Object AND duplicate the linked file?
  • Duplicate Smart Object AND duplicate the linked file?
    Posted by Greg Neumayer on February 1, 2008 at 8:19 pm
    I’ve got a text area I’m building in Photoshop, and I’ve imported some Illustrator formatted text as a smart object.
    Now, I’d like to make a slightly different duplicate of that text area. So, I duplicate the smart object, but as expected, making a change to either results in both being identical, since they’re both linked to the same file. How do I take that smart object and make a second text area without re-building the text area in Illustrator? Can PS do this?
    The only solution I can think of is to start again by making a duplicate AI file, make my slight changes, then import it to the PSD. Not a huge problem, but I’m afraid something will get goofed along the way.
    Any better PSD-centric solution to this? Basically I’d like to duplicate a layer AND the linked file so they both have their own identical yet separately linked smart objects.
    Greg
    Antifreeze Design
    https://www.antifreezemotiongraphics.com
    Greg Neumayer replied 18 years, 8 months ago 2 Members · 2 Replies
  • Ekim Wahs
    February 1, 2008 at 9:21 pm
    Use the command New Smart Object via Copy from the Layer context menu or Layer/Smart Objects/ menu to create a separate instance of the Smart Object
    Mike Shaw
    Photoshop QE
  • Greg Neumayer
    February 1, 2008 at 11:47 pm
    Ah, so THAT’S what that command means.
    Thanks! I’m glad they already thought through this process.
    -Greg
    Antifreeze Design
