Activity › Forums › Adobe After Effects › Duplicate setting in Render queue
  • Duplicate setting in Render queue
    Posted by Kevin Gonzales on August 29, 2009 at 7:57 pm
    I’m looking for a cut and past solution in render queue, if it exists. I have a ton of comps I want to render but don’t want to have to go into each one in the render queue and change each setting for each comp. Is there a way, after you get the settings for one, to cut and paste those settings, in the render queue, for the other comps?
    thanks;
    Todd Kopriva replied 17 years, 1 month ago 2 Members · 1 Reply
  • Todd Kopriva
    August 29, 2009 at 9:44 pm
    You can save and apply render settings templates and output module settings tempaltes.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
