Activity Forums Adobe Premiere Pro Duplicate sequence and make it independent Adobe Premiere
  • Duplicate sequence and make it independent Adobe Premiere
    Posted by Carl Matthews on April 15, 2018 at 2:44 pm
    Hi everyone.
    Hoping someone can help me, I’ve tried everything and searched online but cant find the info I need, so now I need to ask for help.Its going to be really hard for me to explaining but here we go…
    The issue is in Adobe Premiere.
    Basically I have a sequence that has some images and some slight animation and masking and I want to know how I can duplicate/copy this sequence and make it so that it is editable as its own separate sequence.
    The problem I am getting is when I change the image in the new duplicate sequence and swap it for a new image, it changes the image in the first original sequence?
    How can I copy the sequence with all the animation and masking and be able to change the image without it changing the original sequence?
    Hope this makes sense.
    Thanks in advance, Carl
    Carl Matthews replied 8 years, 5 months ago 1 Member · 2 Replies
  • Carl Matthews
    April 16, 2018 at 1:25 pm
    I wish it was that simple I would just do it and not have to come here ☺
    Let me give you so more infomation. So I am using a template from Motion Array, it’s basically a corporate presentation there is 20slides each slide is its own sequence and within that sequence is other sequences and effects and such to make the image and text move as each slide plays through. What I have a problem with is when I try to copy one of the sequences to make a new slide with a difference image it swaps the image on the original sequence too. how are these linked like this and how can I make them work independent?
    Thanks Carl
  • Carl Matthews
    April 17, 2018 at 10:48 am
    Turns out it is really simple.
    Spoke to someone at Motion Array, below is how to do it. Basically import the full project into the currant project.
    “This tutorial will help you duplicate elements in Premiere https://motionarray.com/tutorials/premiere-pro-tutorials/templates/duplicate-elements-in-premiere-pro-tutorials
    You can also re-import the same project into the current one that you have open and then you will have a new set of placeholders in that imported project. You can repeat the process. Alternatively, you could “save as” different projects, and export different quicktimes that you can then piece together back in Premiere. Check out this video that you may find helpful: https://motionarray.com/tutorials/importing-premiere-projects-into-premiere-projects. Hope that helps.”
    Thanks for your help though
