Activity Forums Apple Final Cut Pro Duplicate project as snapshot…has stopped working…arrgh
  • Duplicate project as snapshot…has stopped working…arrgh
    Posted by Jim Bachalo on July 27, 2014 at 12:50 pm
    I have a 7 minute project, not overly complex, but not simple either. 4K footage, lots of compound clips, but none nested more than 2 deep.
    Up until recently I was able to duplicate my latest project as snapshot without issues.
    But this morning I see spinning beach ball for a couple minutes, followed by the loading progress indicator and then….nothing! No error message and NO snapshot!
    I am able to duplicate as a regular project without snapshot.
    Could this have something to do with a corrupt library, or perhaps lack of disk space?
    You should follow me on Twitter here. My latest work
    Jim Bachalo replied 12 years, 1 month ago 2 Members · 2 Replies
  • Craig Alan
    July 27, 2014 at 9:30 pm
    make sure nothing is being processed in the b.g. command-9
    easy enough to check your media drive or storage location options and get info in the finder will tell you about remaining space, though a snapshot is a tiny little file. but regardless I would be very careful to not go beyond 80% capacity on any drive.
    a snapshot is treated as an edit. command-z will actually undo it, much to my surprise when i took a snapshot and then undid all things I had done because I wanted to compare where I had been and where i was going.
    worth a try:
    Reset preferences in Final Cut Pro X 10.1.2
    Quit Final Cut Pro X.
    Hold down the Command and Option keys while reopening Final Cut Pro X. A window will appear asking “Do you want to delete preferences?”
    Click Delete Preferences. This command removes the preference files and resets Final Cut Pro X to default settings.
    Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
  • Jim Bachalo
    July 28, 2014 at 2:12 pm
    Thanks. All good tips
