Activity › Forums › Adobe After Effects › Duplicate plug ins in After Effects CS3
  • Duplicate plug ins in After Effects CS3
    Posted by Bob O’hearn on April 11, 2008 at 7:13 pm
    I installed AE CS3 without uninstalling AE 7.0 and now I can’t even open the program for about ten minutes while I click through all the duplicate plug-in error messages. The problem is I don’t know where those duplicates are. I have looked all over but I can’t locate them. I uninstalled AE 7.0 completely and no luck. Any help here would be greatly appreciated.
    Bob
    Jon Simmons replied 18 years, 5 months ago 4 Members · 5 Replies
  • Lloyd Alvarez
    April 11, 2008 at 7:55 pm
  • Curious Turtle
    April 11, 2008 at 8:05 pm
    Hi Bob,
    CS3 and V7 should co-exist peacefully on the same system.
    I think you problem is that your plug-ins are copied to both the main After Effects folder (C:\Program Files/Adobe/After Effects CS3/Support Files/Plug-ins) and to the Adobe Common
    Plug-in folder (C:\Program Files/Adobe/Common/Plug-ins/CS3).
    To check move or add a tilde ~ to the front of the MediaCore folder shortcut in the main plugin folder.
    Hope that helps,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
  • Bob O’hearn
    April 11, 2008 at 11:08 pm
    Hi Ben,
    Still a little confused. I do remember copying and pasting ny plug ins to my plug ins folder. Do you know of a way to find and delete them?
    Thanks so much
    Bob
  • Curious Turtle
    April 12, 2008 at 5:15 am
    If you’re on Windows, then go to the location in my previous post and you’ll find them there.
    If you’re on Mac, then it’s in (if memory serves): Applications > Adobe > After Effects CS3 > Plug-ins
    All the best,
    Ben
  • Jon Simmons
    April 22, 2008 at 6:14 pm
    I recently installed the Knoll Light Factory 2.0 update to AE CS3 and I’ve now run into the same problem. I do have AE 7 in the applications folder but there is only KLF and that lives in the AECS3 plug-in folder. If I search for them the only ones found are those in CS3.
    Anyone have this issue? Any solutions? Did you figure out your issue Lloyd?
    Jon Simmons
    Producer
    Giaronomo Productions
