Activity Forums Apple Final Cut Pro Duplicate multicam clips crash
  • Duplicate multicam clips crash
    Posted by Jeff Wilmes on July 30, 2012 at 4:50 pm
    Needed to duplicate projects and events to new drives…
    Looks like everything transferred properly, however in timeline where I have multicam clips it says missing and no thumbnail… no red that media is missing, just the word missing where clip name would be in timeline… look in event browser and multicam clip is there…. clips that were used to create multicam are there…
    attach old drives and clips show media as it links itself back to old drives…. I tried just duplicating multicam clips and it crashes…. any thoughts?
    using MBP 2.5 GHz Intel Core i7 8GB ram
    Jeff Wilmes replied 14 years, 1 month ago 3 Members · 4 Replies
  • T. Payton
    July 30, 2012 at 5:16 pm
    Are you duplicating within FCP or are you doing this at the Finder level?
    T. Payton
    OneCreative, Albuquerque
  • Jeff Wilmes
    July 30, 2012 at 6:59 pm
    Within FCP…. all files appear to be relinked… having issue with re-linking two files “…not being long enough to cover…” checking to see if these are associated with multi cam clips….
    Also tried to duplicate single clip (not multi cam) and fcpx crashed…
    thanks,
  • Michael Garber
    July 30, 2012 at 10:37 pm
    I had the same issue. I fixed it by going to the Project Library, select the project, open the info pane, and select modify event references. Now, just click on the correct drive (even if it’s the only one in there). That should bring it back.
    Michael Garber
    5th Wall – a post production company
  • Jeff Wilmes
    August 1, 2012 at 11:50 pm
    Thanks Michael, that did it….
