Activity Forums Apple Final Cut Pro Legacy Duplicate item file name after using media manager
  • Duplicate item file name after using media manager
    Posted by M Brown on December 21, 2006 at 4:49 am
    I’m crashing a 15 minute trade show promo in 720P/59.94. I ran out
    of hard drive space on my travel edit system, DP 2GHX, 5 megs of ram,
    500 gb G-raid, DecklinkHd card. Rather than media manage the
    project, I chose to delete some un-needed files from the HD and
    ended up deleting my media. Don’t ask??
    Anyway, since I was at this
    stage, decided to take the project into our regular edit space, which
    has Kona II boards with similar computer configurations and our
    record decks.
    At this point, using an AJ HDC 150 deck, when I went to redigitize, I
    get the message “Duplicate Item filename”, the filename is blank and
    the ‘overwrite option is blank, as if the file already exists somewhere.
    Tried using the original project files wiht the same result. Tried
    copying the files and putting them in a bin in the browser, and had
    the same problem.
    Tried this out on a second Kona II system with similar Mac hardware,
    had the same result.
    I’m in the process of moving the traveling edit system into our
    office, but would appreciate any ideas on how to solve this issue.
    The only thing I can see is that this was a BM, FCP file and I’m
    trying to use it on a Kona II system. that shouldn’t be a problem,
    but??
    I still have several hours of work to do on the DVD, so if anyone has
    any ideas, so I can continue in the early, early AM, I’d be most
    appreciative.
    thx…mason
    M Brown replied 19 years, 9 months ago 2 Members · 2 Replies
  • Joe Paolo
    December 21, 2006 at 8:41 pm
    FCP uses the clip name as the QT file name. FCP thinks there is a file on your scratch disc with the same name as the clip. If this is true, them maybe all you need to do is relink. If you are sure you media is gone then just modify the file name when you get the duplicate message. Add a “1” or “copy” and redig away.
    joe
  • M Brown
    December 21, 2006 at 10:15 pm
    That’s what I would normally do, but in this case the filename box is blank, so for each file I need to type in a name that exactlyu matches the other clip, then add the one or whatever. Something else is happening here. There are no files in my system with similar names and it happened on two other edit systems with their own hard drives.
    thx..mb
