Activity Forums Maxon Cinema 4D Duplicate issue…
  • Duplicate issue…
    Posted by Brian Keith on January 25, 2007 at 7:17 pm
    I am trying to make an object 12 or so times to be placed around a cylinder. So I am thinking that I should use Duplicate. When I use it, I am trying to make it follow the path of a spline. Well after I hit apply it looks like a garbled mess in the center. After trying to tweak the settings I have become more confused. Should I be looking at Array for this?
    Mikeh64 replied 19 years, 7 months ago 2 Members · 1 Reply
  • Mikeh64
    January 25, 2007 at 10:42 pm
    you could use the duplicate function – make a spline where you want them (use a helix spline as a start), use the “along spline” mode, and enable rotation
    you could use the array tool
    you could also use mograph and clone them on to the cylinder using object mode
