Activity Forums Apple Final Cut Pro Legacy Duplicate frames, Frame rates and other joys
  • Duplicate frames, Frame rates and other joys
    Posted by Jack Bonnett on June 20, 2012 at 4:22 pm
    Hi I just thought that I’d check with people more knowledgeable about this sort of thing then myself before wading in to deal with things on my own.
    We’ve recently been sent a number of clips to re-purpose for a client. They sent the clips over as large progressive HD H264 files which is far from ideal but that’s all we’ll be getting. As I was sorting through them I noticed that most of them were 29.97fps but one was 23.98fps. Irritating but not the end of the world.
    However what I have also noticed is that all the 29.97 clips have a duplicate frame every fourth frame. I’m assuming that this is because they have been incorrectly standards converted from 23.98 in the first place. Would that be a logical assumption?
    Also I was wondering if I was missing anything here because Compressor handles the 23.98 clip absolutely fine but the UI slows down hugely when working with any of the 29.97 files. The encode speeds are fine but there is obviously a lot of processing going on when I try to access one of these files in Compressor. I was wondering then if maybe they had some sort of pulldown or anything embedded in them that I wasn’t seeing. Is this even possible?
    Is there anything I can do about this or is it just a case of the client working with already faulty third generation clips and now being stuck with them?
    Thanks for all your great help so far.
    Jack Bonnett replied 14 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
