Activity Forums Apple Final Cut Pro Legacy Duplicate FCP Clip Edit Markers into Sequence Markers
  • Duplicate FCP Clip Edit Markers into Sequence Markers
    Posted by Jack Nastowski on May 13, 2006 at 8:55 pm
    I have a clip with edit markers. I there a way to drop it into a sequence and have those edit markers duplicate into Sequence Markers automatically?
    Has anyone written a script that does this?
    Jack
    Nick Meyers replied 20 years, 4 months ago 2 Members · 3 Replies
  • Nick Meyers
    May 13, 2006 at 11:23 pm
    XML2text will do that.
    find it here:
    https://www.spherico.de/filmtools/
    nick
  • Jack Nastowski
    May 13, 2006 at 11:51 pm
    It seems like this program deals only with sequences.
    I need to take a clip, which has markers, from the viewer window and insert it into a sequence. When it inserets- I need those edit markers from the clip to pop up in the sequence’s timeline. Basically, the markers will duplicate over the sequence.
    Additionally, I would like those edit markers to automatically be Chapter Markers.
    Jack
  • Nick Meyers
    May 14, 2006 at 1:44 am
    that’s a feature request!
    pretty sure XML2text will do what you need: “Get Clip level Markers out of a Sequence and lift them to Sequence level markers”
    not sure it’ll be quicker than doing it yourself.
    cut clip into seq.
    export XML
    doctor it in XML2text,
    re-import to FCP
    if you have a lot to do, or if this is a way you work regularly it’d be a good thing to get.
    otherwise, cut your clip in to the sequence first, then add markers.
    no way to add a marker and have it be a chapter marker automatically.
    or even turn it into one with a shortcut.
    that’s bad design on FCP’s part.
    nick
