Activity Forums Adobe After Effects Duplicate comp can not change video & text
  • Duplicate comp can not change video & text
    Posted by Ronald Czarnecki on March 17, 2015 at 2:30 pm
    I bought a template with comps 2-8 having picture and text. I wanted to make one more comp so I duplicated comp 8 but found I could not change the video or text without affecting the original comp.
    Any idea what is connecting these two comps together?
    see example below
    Ronald Czarnecki replied 11 years, 6 months ago 2 Members · 4 Replies
  • Walter Soyka
    March 17, 2015 at 2:52 pm
    When you duplicate a comp, it only duplicates that specific comp. Other precomps referenced in that duplicated comp’s timeline are not duplicated — so that Text_edit precomp in your Scene_08 is the same one referenced in the one you duplicated (Scene_07).
    To replace the original Text_edit (07) precomp with the Text_edit (08) precomp, select the Text_edit (07) layer in the timeline, then hold Alt while dragging the Text_edit (08) item from the project panel onto the timeline.
    To duplicate an entire composition tree (the comp and all precomps contained within it), see this script:
    https://aescripts.com/true-comp-duplicator/
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Ronald Czarnecki
    March 17, 2015 at 3:32 pm
    Thanks, not understanding this is holding me up. I think I may have not been clear. In the picture I duplicated Scene 8 which created scene 10, in scene 10 the comp says scene 8 and any changes I make in scene 8 will show up in scene 10.
    I can import and drag new video from the project window using alt into the scene 10 timeline but this changes scene 8.
  • Walter Soyka
    March 17, 2015 at 4:05 pm
    [Ronald Czarnecki] “In the picture I duplicated Scene 8 which created scene 10, in scene 10 the comp says scene 8 and any changes I make in scene 8 will show up in scene 10.”
    Duplicating a comp does not create and link duplicates of every footage item or precomp it contains.
    If you have a Scene_08 which contains a comp named “Text_edit” and you duplicate Scene_08 to make a Scene_10 — they both still refer to the same “Text_edit” precomp. You have to also duplicate that Text_edit precomp and replace the old one from Scene_08 in the Scene_10 comp.
    Alternately, check out the True Comp Duplicator script I linked to, and use that to duplicate your Scene_08. It creates and relinks duplicates of every precomp to create completely independent copies.
    Walter Soyka
  • Ronald Czarnecki
    March 17, 2015 at 5:13 pm
    Thank you Walter that “True Comp Duplicator” worked very well.
    I assume this is way easier then manually trying to copy and unlink to the original.
    Purchase True Comp Duplicator
