Activity › Forums › Apple Final Cut Pro Legacy › Dummy QUestion
Dummy QUestion
Posted by Mabel Lau on June 5, 2013 at 1:35 pmI was wondering if it’s possible to install FCP 6 and FCPX together in one computer? Would there be any complications? Thanks a lot.
Sascha Engel replied 13 years, 3 months ago 4 Members · 3 Replies -
Mark Suszko
June 5, 2013 at 9:25 pmPossible, but when you install X, it will “hide” the earlier application in a new folder, at first it may look like it wiped it out. But it should all still be there and still work, if it worked before you added ‘X”. This is what i heard from people using FCP7 and adding X. Dig out the icon for FCp6 from th folder and put it back in your dock and now you should have both apps available. Though I would NOT try to run them at the same time, close out of one all the way before opening the other.
Bret Williams
June 6, 2013 at 5:23 amThe problem may be in the OS. The FCP 6 installer won’t run in Lion or Mountain lion. And recent builds of X likely require those.
Sascha Engel
June 18, 2013 at 10:53 amI will have a new system soon, running OSX 10.8 : Do you know, if my FCP 7.0.3 will still run in that environment?
Thanx for feedback.
greetings,
Sascha Engel
TIME BANDITZ Productions
http://www.youtube.com/taikang
