Activity Forums Apple Final Cut Pro Legacy Dummies Guide to Recapture
  • Dummies Guide to Recapture
    Posted by Jeff Scott on January 25, 2008 at 2:11 am
    I’m finishing post on a feature doc…cut the rough using the DV masters. Created a new 8 bit D1 Sequence and copied DV timeline into it. Recently recaptured all the SOTs from Beta SP through my Kona LH and replaced all the DV clips with the newly captured 8 Bit Uncomp. material. It worked EXCEPT now I have to nudge every replaced clip up one frame for the 720×486 Sequence.
    Any way to do this and avoid the time consuming “Frame Shift” process?
    Jeff
    G5 Dual 2.0Ghz
    Final Cut 6.0
    Kona LH + io HD
    Jeremy Garchow replied 18 years, 8 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    January 25, 2008 at 3:52 am
    Yes. Media manage to an 8 or 10 bit D1 sequence and recapture. The Kona will take care of the nudge. For a rough guide on how to do this, see here:
    https://www.kenstone.net/fcp_homepage/basic_onlining_jordan.html
    Jeremy
  • David Bogie
    January 25, 2008 at 4:08 am
    You guys are saying timecode isn’t really absolute? It’s relative? Timecode depends on the capture source?
    Aw, crap. I shall remember this but I’ve got to recant a couple hundred posts.
    bogiesan
  • Jeremy Garchow
    January 25, 2008 at 4:14 am
    Good point. I am assuming you have your timecode correct.
