Activity Forums Panasonic Cameras dumb move
  • dumb move
    Posted by Wizz_kydd on March 29, 2007 at 3:02 pm
    yeah well jus got the fs-100 portable hard drive and started shooting right away but now that i am ready to edit i have problems i shoot 4 3 days and when i finally did my reseach i got the last day of shooting to be ok in fcp the prob now is that the last 2 days i had i backed up on my computer i did not back up the last clip TXT file (which i did not no bout till the research) 4 those to days so jus wanted to no if all is lost or is there some way to get those files in fcp
    Wizz_kydd replied 19 years, 5 months ago 4 Members · 5 Replies
  • Izoneguy
    March 30, 2007 at 5:41 am
    The lastclip.txt is only needed if you have clips spanning 2 cards. You can always join the two clips together in editing.
  • Suncloud
    March 30, 2007 at 11:13 pm
    I shoot w/ the Firestore and you still need to have the Lastclip text file to read the P2 format . . . and also, I’ve heard that each Lastclip.txt file is NOT unique . . . it’s the same file, so you can copy one and place it in w/ your P2 formated file structure, making sure it’s in the right place.
    Grant Taylor
    SunCloud Productions
    Santa Fe, NM
  • Izoneguy
    March 30, 2007 at 11:28 pm
    I just did a test, you do not need LASTCLIP.txt to import P2 into FCP.
    The LASTCLIP.txt is unique to each P2 card you shoot.
    Open up some LASTCLIP.txt and you will see it
    does have the clip number of the lastclip in
    your video folder contained in the CONTENTS folder.
  • D. scott Dobbie
    March 31, 2007 at 4:30 pm
    “. . and also, I’ve heard that each Lastclip.txt file is NOT unique . . . ”
    That’s NOT CORRECT. It’s a text file – just open it up and look at it and you’ll see they’re different.
    They are also used to link spanned clips, which they could not do if they were all the same.
  • Wizz_kydd
    April 2, 2007 at 6:38 pm
    well the thing is that i have the files that wuz on the drive b4 it oragnize to make the contents folder
