Activity Forums Adobe After Effects Duik IK handle script problem
  • Duik IK handle script problem
    Posted by Sergio Juyak on November 3, 2009 at 8:15 pm
    I’ve been trying to use this Duik script for creating IK solvers for a stick figure, and it’s not working. According to the tutorial video, I’m supposed to:
    A) set up the anchor points and parent the layers appropriately
    B) create a controller for the extremety (a hand in this case)
    C) select the extremity, up to the root, and then the controller
    D) click the Create IK button
    I took a video of this and the result has my hand flying off in random directions… anyone know what i could be doing wrong?
    https://tinyurl.com/ylyd934
    Stuart Amos replied 16 years, 7 months ago 3 Members · 2 Replies
  • Gal Narunsky
    January 18, 2010 at 2:27 pm
    hey,
    i ran into the exact same problem with the hands and feet flying off in strange ways. Did you find a solution for that?
    please please please
  • Stuart Amos
    January 29, 2010 at 8:56 pm
    Hi there,
    Try pre-composing the layers before you add the IK (making sure you re-adjust the registration point, of course). DuIK is very sensitive if you’ve modified the layers, especially scaling them, prior to adding the IK.
    Hope that helps,
    Cheers,
    Stu
    https://www.vimeo.com/famos
