Activity › Forums › Adobe After Effects › Duik IK and Puppet Tool
Posted by Pat Bray on May 23, 2012 at 12:09 pmHi
I was hoping to use Duik’s IK tool to rig and animate a horse illustration. I followed the tutorial example he has on the website using a solid, precomping and then puppet pinning three points etc etc, which worked fine, so I tried the same thing on one of the horses limbs but keep getting a ‘Select the bones and the controller before creating IK’. I really can’t figure out what I’m doing differently to the tutorial other than using a precomped png file rather than precomped solid.Has anyone else had this problem of can offer a solution?
Marieke Hannen replied 8 years, 3 months ago 9 Members · 9 Replies -
Andy Galloway
May 24, 2012 at 9:14 pmHi mate,
Been a while since I used Duik Ik but I think you get that message if you do not have the bones and controller highlighted in you timeline when you push the Create IK button. Also I seem to remember you have to highlight them in the specific order of hierachy moving upwards.
I don’t know if that helps but let me know how you get on.
Good luck.
Gavin Edwards
July 13, 2012 at 9:01 pmI’m getting the same problem and warning box as Pat. Have tried with original psd artwork and precomping it to no avail.
Does anyone have a solution to this? Much appreciated if you do.
Ben G unguren
July 17, 2012 at 3:38 pmCheck your parenting hierarchy. Also, make sure you select the layers in the correct order (hand->lowerArm->upperArm->handController). I’ve gotten that message and in most cases redoing the parenting and/or selecting seems to do the trick.
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Tom Smith
January 22, 2013 at 12:55 pmSame problem. Weird thing is on my project, the arms are PSD layers and so is the legs but the feet are precomped to include the toes. arm works but feet dont. I get that same error and the is ZERO English tutorials on the current version of this.
Where are all the nerds that speak French?
lol -
Gerald Hapeman
March 29, 2013 at 3:51 amSorry to chime in, but yep, same problem. Precomping doesn’t work either. I’ve done everything by the book, word for word and still the problem. I know Dan Geis has his latest tutorials up for rigging with Duik on his Rocket Randee so maybe he provides some info there…?
Peter Kmeť
January 9, 2014 at 12:36 pmHi Pat
I had the same issue, but i findout the reazon – you can youse only 3points.
here is also tutorial (2nd one):
https://duduf.net/?page_id=169as you can see, for creating “S” is used 2 IK chains with 3 joints,,,
Steve Bentley
May 24, 2018 at 3:51 pmYou can use more than three points for sure. It might be that with 4 legs your joints are looping around on themselves. Try treating each leg separately then link them to the parent body (you may be doing this). I’m doing a horse right now and it’s all working fine.
Marieke Hannen
May 24, 2018 at 4:11 pmI don’t think you can use more than 3 bones+1 controller to create IK. If you use more than 3 bones you get the above error message.
Your approach seems legit, I’m going to try it! Do you have a link to a decent tutorial maybe ☺
