Activity Forums Adobe After Effects Duik and the Puppet tool
  • Duik and the Puppet tool
    Posted by Nick Vaka on December 18, 2013 at 6:12 pm
    Hi there!
    I’m attempting to create a rig for a biped using Duik and the puppet tool in AE CS6. The problem I’m running into is that after I’ve finished the rig on the one arm, I’ll go to create a bone on the next one and the bone from the first arm with cling to its corresponding bone on the second. I’ve attached a screenshot using two small solids so you can see what I mean.
    Do I have to have each puppetted limb pre-composed with its controllers and bones separate from the main character? (note, I tried pre-composing and leaving all the attributes in the comp seen here, but that didn’t work either. Only seems to work if I completely precompose).
    Any help is greatly appreciated.
    Nick Vaka
    Motion Graphics & Animation
    https://www.nickvaka.com
    Nick Vaka replied 12 years, 9 months ago 2 Members · 3 Replies
  • George Goodman
    December 18, 2013 at 6:57 pm
    Did you rename the pin points from the puppet tool before creating the bone? You need to do that or else when you go to the the next layer and use the puppet tool, it will create points with the same name and everything will get all wonky.
    “|_ (°_0) _|”
    Sincerely,
    George
  • Nick Vaka
    December 18, 2013 at 7:00 pm
    I did not! I’m willing to be that’s exactly what’s going on here.
    Thanks! Will try renaming and let you know if it’s still being wonky.
    Nick Vaka
  • Nick Vaka
    December 18, 2013 at 7:08 pm
    That did it! Started acting wonky at first, but I just created a new solid with unique pin names and it’s all peaches and cream now.
    Thanks again for you help!
    Nick
    Nick Vaka
