Activity › Forums › Apple Final Cut Pro Legacy › Duh…lower field or upper field first
  • Duh…lower field or upper field first
    Posted by Winrockpost on June 15, 2006 at 1:10 pm
    Rendering out a thirty second broadcast spot from vegas to be finished in FCP, all just photos and graphics, for FCP should I render quicktime uncompressed ,which field first ?
    thanks in advance
    Winrockpost replied 20 years, 3 months ago 6 Members · 15 Replies
  • 15 Replies
  • Winrockpost
    June 15, 2006 at 1:14 pm
    Oh,, NTSC SD going to Beta
  • Andy Mees
    June 15, 2006 at 1:17 pm
    Uncompressed should be Upper field first
  • Winrockpost
    June 15, 2006 at 1:18 pm
    Thank you much
  • John Pale
    June 15, 2006 at 1:59 pm
    Uncompressed SD is Lower Field First in NTSC for most equipment (old Avids and Media 100 used upper)…PAL uses upper field first for SD.
    In DV its lower field first for both PAL and NTSC
  • Andy Mees
    June 15, 2006 at 2:06 pm
    good catch! the danger of living in PAL land and giving out advice … i shall hush my mouth 🙁
  • John Pale
    June 15, 2006 at 2:11 pm
    [Andy Mees] “good catch! the danger of living in PAL land and giving out advice … i shall hush my mouth 🙁
    Hey, your advice was correct for the majority of the planet. (however, since winrockpost didnt say where he was from, I was assuming the US..could be wrong, though)
  • Andy Mees
    June 15, 2006 at 2:35 pm
    but he/she did specifically post that it was NTSC . ah well, we all make mistakes (just some more often than others!)
  • Bob Flood
    June 15, 2006 at 7:43 pm
    Hey
    are you sure about Uncompressed NTSC and DV ntsc having the same feild dominance? I could not tell you off the top of my waht its supposed to be, but everytime i go into setup, i see the prompt that sez “all video is yadda yadda first except dv which is doda doda”
    soooo i think DV, DVCPRO, DVCPRO50 and maybe even DVCPROHD NTSC are upper field first?
    bee eph
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
  • Winrockpost
    June 15, 2006 at 8:05 pm
    thanks all ,glad I checked back!!!
  • John Pale
    June 16, 2006 at 1:20 am
    DV, DVCPRO, DVCPRO50 are all lower field first in NTSC.
    DVCPRO HD is upper for 1080i. No fields for 720p
    PAL DV formats are lower field first, but SD is upper.
