Dubbing spots with different numbers
Hello Everyone..
We normally do Tv spots x DR, and have to master same spot with multiple phone #, our last project was a long form 28:30 infomercial, that the client what to dub with 50 phone #’s, so like to ask if someone have a good workflow to share in order to avoid multiples renders..
Here is what we have and normally do.
Finalize cut and flatten on a 480i Uncompress 10bits quicktime
Create one sequence with the master QT, and add a 2nd layer with a png+alpha with the phone #
FCP preview without rendering (green bar) but if when edit to tape, star render all spot.
If we do the math, for 50 spots of 28:30 it will take days to master, so need a better workflow.
We also try to use the text tool to add the phone #, but same result.Our systems have very similar config:
Intel Quad 2.5mhz, with 16M Ram, Kona 3, FCPS 3 Os. 10.5.8, mastering to DigibetasWe also considering use a Dub house , but like to try it first, so any direction is very welcome..
JC
