Activity › Forums › Adobe Encore DVD › Duallayer Problem in Encore CS5
  • Duallayer Problem in Encore CS5
    Posted by Can Köprülü on July 11, 2010 at 10:29 am
    I have a weird problem with Adobe Encore CS5. I am using the german version so i dont know if my translations are all 100% the Adobe translates them…. here we go:
    I setted up an DVD withe menus and several timelines using arround 7 GB of space on the disc.
    When i want to create the disc, the program stops while preparing the DVD structure saying: “DUALLAYER – this Disc needs an layer break” It’s exactly the same problem when i set the layer break to automatic or mannual. When i set it to manual, no window appears where i could set an chapter for the break…
    Does anyone know this problem, or even better how to solve it?
    Daniel Ludwig replied 16 years, 2 months ago 2 Members · 1 Reply
  • Daniel Ludwig
    July 12, 2010 at 2:19 pm
    I haven´t created a DL-DVD with encore, because I only use it for BDs, but I bet, you have no chapter-markers at the valid layerbreak-position/zone, that´s the reason why encore could not create a DL-DVD from your project.
    if you need to set a layerbreak, it could easily be done with DVD AfterEdit, and also create replication masters with the mastering-version of it.
    https://dvdafteredit.com/
    you could set it at ANY cell you want to – but you need to have a multiplexed DVD.
    there is also a demo-version of it, so you can look for a valid layerbreak-position.
    cheers
    danny
