Activity Forums Adobe Premiere Pro Dual system Audio on Premiere Pro CC 2014
  • Dual system Audio on Premiere Pro CC 2014
    Posted by Dale Hildebrand on June 6, 2015 at 8:47 pm
    Any guidance is appreciated. Starting a new project (feature film) and trying to sort out audio post flow. Here is what I have and what I want:
    – R3D files (most 6K)
    – Recorded dual system audio, plus simultaneously fed all the audio to Right and Left on camera. So in essence I have a guide track I can cut to.
    – Merged clips in Premiere for the first 8 days of footage, but now thinking this is a mistake (footage is often out by a few frames, now I have to go in and fix, merged clips don’t seem to retain markers). Want to correct this now before I get too deep into this.
    – Merged audio clips have head and tail audio handles that constantly need trimming. If you trim the head to picture start in timeline, picture will be linked to the portion of audio you are trying to remove, not the parallel audio directly below the video track. As a result, you have to constantly cut a few frames in to the picture. This is very time consuming.
    – I could just bring the clips onto a timeline, sync to head slate (even though I have timecode sync/jam for 99%), then “group” or “link” (audio, video A-camera and B-camera). However, if I “group”, I can not double click to get image up on source window, I have to unlink all tracks then relink all tracks (Video & audio), then drag to a bin (where it asks to “merge” clip) to do this. So I’m back at square one.
    – Pluraleyes?
    Trying to find a solution that helps keep the premiere post flow/picture edit a little less clunky and faster to work with.
    Dale Hildebrand replied 10 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
