Activity › Forums › Apple Final Cut Pro Legacy › Dual Stereo audio from an Aja Io-La?
Posted by Tom Matthies on December 18, 2007 at 12:49 amIs it possible to send a dual stereo signal out of an Io-La?
I’m looking to send channels 1&2 out of both channels 1&2 and 3&4 of my Io-La without the need to duplicate my audio tracks and assign their outputs from the Io.
Basically I’m looking to send a stereo mix of my time line to two locations at the same time via the Io-La. Dual stereo if you will.
Is it do-able?
Thanks in advance,
TomTom Matthies replied 18 years, 9 months ago 3 Members · 7 Replies -
Jeremy Garchow
December 18, 2007 at 1:26 amThe io will not Duplicate and reassign your outputs for you.
You will have to set up this matrix via FCP. It is very easy to do.
Jeremy
Tom Matthies
December 18, 2007 at 3:22 amI have a sequence, set up to output 2 channels of audio thru the Io-La. The sequence has 8 channels of audio, panned either left or right. This will give me a stereo, mixed output from output #1 & 2 on the Io. Pretty straightforward.
If I create a sequence with four channel output enabled, I’m looking for a way to, for instance, send A1 to both Io output # 1 & 3 and to send A2 to channel 2&4 at the same time. If I look at the channel assignment dialog in the mixer window, it only gives me the option to “send” each audio track to a single output on the Io.
I’m outputting a long program via Compressor right now, so o I’m locked out of the program and can’t access the help menu at the moment. Can you give a quick walkthrough of the procedure to output dual stereo?
Tom_PS I hate late evening deadlines.
Jeremy Garchow
December 18, 2007 at 6:25 amYes. Simply export your 8 channels as a stereo file. Bring that back in to FCP. Duplicate your timeline with the 8 audio channels, delete them. Place your stereo track in 1&2, and also 3&4. Alternatively, you can set the newly imported stereo mix on their own tow channels. Setup your audio matrix to output tracks 1&2 (or the 8 channels of audio) as stereo on outputs 1&2, then setup the imported stereo mix on 3&4.
Hope that helps.
Jeremy
Tom Matthies
December 18, 2007 at 5:43 pmThanks Jeremy. Actually that’s pretty much the way I was doing it as well. I was just wondering if there was an easier way to simply assign a track to two different outputs rather than a single one. I had been just duplicating the audio tracks and then reassigning the outputs, but the export/import method would certainly make for less tracks.
The reason I was trying to do this was to use the 3/4 outputs from the Io to feed a Tektronix audio level/phase meter without needing to DA the outputs. I got in multiple camera footage from a live concert that has several of the audio channels out of phase and I figured that watching the phase monitor would tip me off early that there are phase cancellation problems with a given clip before getting too far into the process. I guess setting up a simple calibrated audio DA would solve the problem and wouldn’t cost too much. I probably have an old Grass Valley rack down in the pile-where-things-go-to-die in the basement.
Thanks for the help!
Tom -
Jeremy Garchow
December 18, 2007 at 6:13 pmI hear you. The export and duplicate method shouldn’t take but a minute or two and you won’t have to resurrect the dead from the basement. 🙂
Jeremy
Pat Defilippo
December 19, 2007 at 11:23 pmWould this work and be one less step?
What if you simply made a new sequence and then dragged in your master sequence with the 8 audio tracks? Then, hold down your Option key to copy/duplicate audio tracks one and two to three and four before outputting to all four tracks via your Io LA.
This way, you’d get two additional benefits over Exporting:
1) No extra time or disk space doing this (which is minimal anyway)
2) If you ever make revisions in your master timeline (the one with the 8 tracks), it will automatically ripple through to the output timeline (with the duplicated audio, the way you’d like it to go through your Io LA).When I was linearly editing, by the way, I used master audio differently than the way you described. I’ve never done this with FCP yet, but I used to put the stereo audio on 1 and 2 (exactly how you described) but then I would put Narrator/SOT on 3 and SFX & Music (Mono) on 4. I’m just bringing this up because you might be able to take better advantage of the four audio tracks for easier possible re-editing down the road via the Io LA than dual stereo. If I had more than just a UVW-1800 (which is 2 audio channels only) hooked up to my Io LA, this is exactly how I’d master everything.
Just an idea!
-PatG5 Quad 2.5 Desktop with 4GB Ram, 500GB HD & Fiber Card ~
30″ Cinema Display & 17″ Sony SVGA ~
Swift Data 200 Internal 1.6TB SATA II RAID 0 ~
AJA Io LA ~
Final Cut Studio 2 ~
Sony UVW-1800 Beta-SP ~
Sony DSR-40 DVCam ~
2.33ghz MacBook Pro 17″ (with FCS2) ~~~P D Post Productions, Inc. ~
TV~DVD~VHS~CD~WEB
for Corporate Communications, Commercials, Infomercials, Television Programs and Family Occasions since 1983 ~
E-mail PD@PDPost.com ~
Website http://www.PDPost.com ~
Business/Cell Phone (847) 275-5671 -
Tom Matthies
December 20, 2007 at 1:37 amThanks Pat.
That’s actually how I’ve been duplicating my tracks-Option/Shift + Drag to the new tracks.
I guess it works so I’ll just keep doing things the same way. Just thought there might be a more elegant way to do it.
Tom
