Activity Forums Apple OS X dual screen resolution
  • dual screen resolution
    Posted by Gary Jarvis on October 6, 2012 at 3:59 pm
    I have an apple cinema at 1920×1200 and a dell 1920×1080 is there anyway I can set up the same resolution on both, I understand that I will lose a little in the screen size. The main reason is when I try to play a Playback pro tutorial on one screen and, operate playback pro on the other screen the screen with the video playing screen goes black.
    Tks Gary
    Curtis Thompson replied 13 years, 11 months ago 2 Members · 1 Reply
  • Curtis Thompson
    October 9, 2012 at 5:15 pm
    hello…
    if your system/card/monitor lets you do it? i take it that it doesn’t and you are looking for a way to override that? also, your monitor would like skew the aspect ratio to make it fit anyway, which i would suspect would drive you nuts pretty quickly…
    sitruc
