Activity › Forums › Adobe Premiere Pro › Dual nVidia Quadro 4000 in Mac Pro
  • Dual nVidia Quadro 4000 in Mac Pro
    Posted by Trevor Schrodt on September 4, 2013 at 6:23 pm
    Is it possible to run two Quadro 4000 in a Mac Pro and take advantage of both of them in Premiere Pro, After Effects and/or C4D?
    Thank you in advance
    Trevor
    Mac Pro 5,1 6-core 2.93GHz
    24 GB RAM
    OS X 10.8.4
    Paul Forcier replied 13 years ago 3 Members · 5 Replies
  • Walter Soyka
    September 4, 2013 at 8:38 pm
    [Trevor Schrodt] “Is it possible to run two Quadro 4000 in a Mac Pro and take advantage of both of them in Premiere Pro, After Effects and/or C4D?”
    Premiere Pro CC supports multiple GPUs during export, speeding up output. Only a single GPU is used during regular playback. Premiere Pro CS6 uses only a single GPU.
    After Effects CS6 and CC can use multiple NVIDIA CUDA GPUs like your Quadro 4000 for the ray-tracing renderer only. The classic 3D renderer does not rely on the GPU at all. OpenGL-based effects like Element 3D will use only a single GPU; multiple GPUs will not further accelerate them.
    C4D’s viewport is OpenGL, and its renderer is CPU-based, so extra GPUs won’t increase performance. If you are using the third-party Octane renderer, it should use multiple CUDA GPUs.
    Walter Soyka
  • Paul Forcier
    September 5, 2013 at 12:55 am
    You may get better performance from the GTX series of cards and take a much lighter hit on the wallet.
    May have to check the capacity of the power supply in the Mac Pro and the number of power leads as well.
    Do a search through the posts…in terms of After Effects me thinks you ll get more bang for the buck with GTX….
    I believe another poster or two mentioned the Quadro would be necessary for higher than 10 bit with a proper monitoring solution though…
  • Walter Soyka
    September 5, 2013 at 1:54 pm
    [Paul Forcier] “Do a search through the posts…in terms of After Effects me thinks you ll get more bang for the buck with GTX….”
    True.
    https://www.loopoutcontinue.com/cuda/
    Walter Soyka
  • Trevor Schrodt
    September 5, 2013 at 2:31 pm
    Thank you for the responses. We’re updating one of our Mac Pros with a Quadro 4000 in it to the new one whenever it’s released. I figured why let it go to waste if it has some uses. Thanks again
  • Paul Forcier
    September 9, 2013 at 3:42 am
    Hey there, also, as a new Quadro (k4000?) and the old one will have a different compute level, I’m not sure that the new and old card will work together with cuda in the way you my be thinking…
    https://developer.nvidia.com/cuda-gpus
