Activity Forums Apple OS X Dual Network on MacPro
  • Dual Network on MacPro
    Posted by Ervin Tia on April 16, 2013 at 9:20 am
    Hello. Just wondering if this is possible – a dual network connection: server & direct to peer. Is it gonna help with speed/transfer? Thanks.
    Ervz | Video Productions | WMC-AP, Philipines
    System 1: Mac Pro/8-Core/10 GB/OSX 10.6.8
    Avid MC/Adobe CS6
    System 2: Windows XP Pro, SP3 / 4 Gig / Intel
    https://vimeo.com/ervzman/videos
    Ervin Tia replied 13 years, 4 months ago 2 Members · 2 Replies
  • Chris Gordon
    May 11, 2013 at 1:30 pm
    Yes, you can do that. You do need to understand IP networking to configure the networks properly on the machines to make it work right.
    Question is why? I assume your LAN1 connections go to a switch (probably a single switch). Unless something is overloaded or you’re already putting heavy load on the the LAN1 connection, you’re not going to see any noticeable change speed changes using your LAN2 cross-over cable idea.
  • Ervin Tia
    May 11, 2013 at 3:09 pm
    Thanks. I’m just wondering if there will be a significant improvement in file transfer/sharing speed..but maybe not …just like you said there will be no significant improvement even when connecting straight instead of going around a server.
    Any other comments?
    Ervz | Video Productions | WMC-AP, Philippines
