Activity › Forums › Adobe Premiere Pro › Dual Mono Audio
Dual Mono Audio
Posted by John Mahoney on September 17, 2015 at 4:39 pmI am sure I am missing something simple. I am used to working with stereo as dual mono.
I have searched and found how to get that in Premiere by using these steps
https://www.premiumbeat.com/blog/stereo-to-dual-mono-premiere-pro/However it only seems to work if I drag the clip into the sequence. If I do an insert or overwrite edit, I get single mono left channel only.
What am i missing?Robert Withers replied 10 years, 11 months ago 4 Members · 5 Replies -
Andy Edwards
September 17, 2015 at 8:53 pm -
John Mahoney
September 17, 2015 at 9:13 pmI cant seem to get A2 to light up.
I am sure I am doing something dumb. -
Alex Udell
September 17, 2015 at 9:52 pmhmmm…
it may to do with how PPro is interpreting the source…
prioir to using a clip on the timeline….if you right click on the clip in the project panel
choose modify>audio channels
this can let you deal with a stereo pair as dual mono…
so then when you load it into the source viewer you will see in the timeline that you have both tracks available for patching…
note though… in terms of applying effects in the timeline…this still might behave the way you expect…
hth…
Alex Udell
Editing, Motion Graphics, and Visual FX
Let’s Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial -
Andy Edwards
September 17, 2015 at 10:15 pm -
Robert Withers
October 26, 2015 at 9:03 pmHi John,
This is not about your question but since you are used to working in dual mono maybe you can help with mine.For no good reason, I have a sequence with 100+ clips recorded in stereo that were all brought in as dual mono tracks.
It seems not possible to combine these tracks into stereo now that they’re already edited in the timeline.
But I want to edit them with:
overlapping edits
cross dissolves
level changes
some equalization and effectsAre there streamlined ways of doing these?
Or do I have to perform each operation on one of the dual mono tracks and then mimic or paste an effect on the other?Prepared to work in either PPro (using 7.2.2) or Audition.
Thanks for any help.
RobertRobert Withers
Independent/personal/avant-garde cinema, New York City
