Activity › Forums › Apple Final Cut Pro › Dual monitors and Mavericks
Posted by Michael Sanders on October 24, 2013 at 12:48 pmDon’t know if this is just me but..
If you have a Mac with two displays, you need to go into prefs -> Mission control and turn off “displays have separate spaces” – otherwise FCPX will treat each screen as a separate screen, and when you select show viewer on second display it will open it up in the same window.
Michael Sanders
London Based DP/EditorAnibal Nunez replied 12 years, 8 months ago 9 Members · 12 Replies -
Bret Williams
October 24, 2013 at 2:48 pmActually, it’ll work. But you need to set it up. For me I had to show the events in the main window (that’s what was on my second display), then make sure the second display was in the finder, then show events on second monitor. Each time you launch X, you need to make sure that second monitor is available to take the events (meaning it’s in desktop/finder), or it’ll put the events on top of your first display.
I too though have turned it off. Premiere and AE have the same issue. And once you’ve got the windows how you like them, you can’t just use app+tab to switch between apps. It only switches one screen at a time. So you have to switch apps, and then mouse over the second screen and swipe (if you’re on a trackpad).
Being on a trackpad makes the whole dual full screen thing a bit easier. But still wonky. And there’s really not much point in full screen apps. A couple pixels added real estate, but you can’t drag between them. It’s just a lot of annoying swipe candy.
Michael Sanders
October 24, 2013 at 3:48 pmHi Bret
I actually managed to get it to work by going to mission contro/spaces (you know by swiping down) and dragging the window to the second screen.
Of course it then stays there if you change spaces on the main screen.
For editing I think I’ll leave it off as its better to move between spaces and have say FCP X make way for Motion on both screen – at least thats I how roll.
Michael Sanders
London Based DP/Editor -
Bret Williams
October 24, 2013 at 3:50 pmI tried to adjust all day yesterday, but turned it off as well.
What was the other reason for going to Mavericks again? Oh well, it was free.
Michael Sanders
October 24, 2013 at 3:53 pmI quite like the tabs in finder.. And Safari seems faster..
Michael Sanders
Steve Connor
October 24, 2013 at 5:12 pmTabs are good, Tags will be good, Safari and the interface itself are faster, much better battery life, better notifications and all the under the hood changes that will be preparing us for FCPX 10.1
Steve Connor
There’s nothing we can’t argue about on the FCPX COW Forum
John Davidson
October 24, 2013 at 8:00 pmAnd if you haven’t turned on enhanced dictation, do it. I set mine to double tap left cmd key to activate. Enhanced checkbox will download 750MBs of data so that dictation doesn’t have to ‘phone home’ like the iPhone does.
It’s so fun.
John Davidson | President / Creative Director | Magic Feather Inc.
Jeremy Garchow
October 24, 2013 at 9:48 pmhow well does it work when you say, “can I have coffee, please?”
Mike Most
October 27, 2013 at 5:49 pmOperating systems are only peripherally about user interfaces. OS upgrades are much more about things like better and wider memory management, improved multitasking schemes, improved networking, new application services, and, well, everything that you DON’T see. Those things are almost always much more significant and important than the things you do see. The things you notice are usually things they had to put in so that, well, you would notice. Things that you might care about, but developers can’t use and really don’t care about.
Dave Gage
October 27, 2013 at 6:55 pm[John Davidson] “And if you haven’t turned on enhanced dictation, do it.”
My son just installed Mavericks last night, so I took a look at the Dictation program. Amazing! I haven’t looked at dictation programs since the ’90s. This works great. I’ve not seen a lick of instructions for it yet, but I tried saying, “comma”, “period”, etc., and it adds them. This may be the inspiration I need to finally upgrade the OS.
Dave
