Activity › Forums › Adobe After Effects › Dual monitors affect Open GL or render time?
  • Dual monitors affect Open GL or render time?
    Posted by Francois Driessen on November 10, 2006 at 10:09 pm
    Hi there. Maybe this is a silly question, but will using a single monitor vs using 2 get better performance from the GPU when running AE? I know the GPU memory gets split and 1/2 gets allocated to each monitor. Could that effect Open GL performance? (I’m balancing the apple 30″ display and two 20″s for economy and system performance. I have an NVidia 6800 Ultra.) Any thoughts?
    Francois
    >- e y e f l a m e .tv –< https://eyeflame.tv
    Francois Driessen replied 19 years, 10 months ago 2 Members · 2 Replies
  • Mylenium
    November 10, 2006 at 10:21 pm
    Well, in your case that is no question at all – the 30″ requires two channels, so it behaves just the same as two separate displays. It certainly affects OpenGL and other display operations, but the memory is not split 50/50. Normal display operations do not require that much memory and depending on the mode there are optimizations. It’s more a matter of proper configuration. OpenGL will only become memory hungry with large “textures” (big comps, 3D-layers), especially since AE has still Adaptive Resolution and you can go back to that mode should things get hairy with OpenGL.
    Mylenium
    [Pour Myl
  • Francois Driessen
    November 11, 2006 at 9:36 pm
    Thanx, M. Almost had an excuse to blow $2300!
    2x 20″ it is then. Unless using a 23″ and a 17″ would make a difference? (since the memory is not split 50/50?)
    Francois
