Activity › Forums › Canon DSLR Cameras › dual monitor output on a t2i?
  • dual monitor output on a t2i?
    Posted by Steve Topper on September 4, 2011 at 7:42 pm
    Is it possibe to connect the t2i to multiple monitors for filming? We are working on a project involving puppetry, and since we aren’t professional puppeteers, it is helpful to see whats going on on camera. But with just one monitor, the videographer can’t see what’s happening as well..
    Jonathan Ziegler replied 15 years ago 2 Members · 1 Reply
  • Jonathan Ziegler
    September 5, 2011 at 6:25 pm
    You would have to split the HDMI signal coming from the camera – if you have the budget, you can send it to a splitter of some form and then hook up monitors. The bummer is that the T2i is sporadic with display – it will show on the external monitor during framing and focus, then it cuts out when you record and then it pops up on the screen again. I highly recommend using a power adapter for the T2i.
    Jonathan Ziegler
    https://www.electrictiger.com/
    520-360-8293
