Activity › Forums › AJA Video Systems › Dual Link RGB 4:4:4 editing with FCP
Posted by Christopher Tay on May 24, 2005 at 3:22 pmHi,
Someone asked if he can capture and edit with FCP in 10bit RGB 4:4:4 injested from a Sony SRW HD VTR and I said why not…use Kona 2.
But then one thing I’m not sure is what happens when you render effects ? Do they stay in 10bit RGB 4:4:4 or do they get truncated down to 8bit ?
-chrispy
Gary Adcock replied 21 years, 4 months ago 9 Members · 17 Replies -
John Ladle
May 24, 2005 at 7:40 pmi assume it wil behave like all 10 bit uncompressed HD in FCP…turn into an 8 Bit pumpkin the moment you render effects…
John Ladle
May 25, 2005 at 3:49 amyeah, funny how it works, kind of. actually, a lot of avids do the same things, if you use certain effects in some of the higher end avid systems with 10 bit uncompressed HD, you get 8bit results.
Christopher Tay
May 25, 2005 at 11:43 pmAny idea which rendered effects will turn a beautiful 10bit 4:4:4 RGB into 8bit pumpkin ?
-chrispy
John Ladle
May 26, 2005 at 11:50 pmfor FCP 4.5/HD–everything. for the avid stuff, it depends. they don’t let that info out too freely. you have to ask the demo guys on the latest list for an avid symphony, for instance
Mike
May 27, 2005 at 2:59 amThis is very interesting to know, but it makes me somewhat confused. Final cut seems to differentiate between “8-bit YUV” and “high precision YUV,” however, the above posts indicate that Final Cut cannot process above 8-bits. So can can someone please explain to me what “high precision YUV” means in terms of 8-bit vs. 10-bit.
Thanks very much,
Mike -
Dom Silverio
May 27, 2005 at 1:10 pmFor XPress Pro and Adrenaline, the ReadMe file states which FX are 16 bit- most of them, including the most commonly used like PiPs, dissolves, wipes etc.
This is based on the latest release [5.x for XPro and 2.x for Adrenaline]. So a full 10 bit workflow is possible.Avid Symphony Nitris will be interesting. Symphony’s old code is 8 bit mostly [only the CC was 10 bit, but SDI out was only 8 bit] but it will be using Nitris hardware. That is 8/10 bit native.
Back to topic…. I thought FCP supported up to 32 bit FP? The engine renders at 32 bit but writes only 8 bit?
John Ladle
May 27, 2005 at 11:01 pmdo express pro and adrenaline allow for uncompressed HD? we are talking 4:4:4 uncompressed dual link HD. last i heard, adrenaline was compressed HD only, but that info was right around NAB. i know avid finally has DVCPRO HD, but i did not think they allowed uncompressed on anything affordable…
Dom Silverio
May 28, 2005 at 3:02 amNo – no uncompress 4:4:4 but we are talking about bit depth here and not compression ratio right?
John Ladle
May 28, 2005 at 4:15 ami think i took it as generally working with dual link footage which would be uncompressed 10 or 12 bit 4:4:4. pretty amazing it is this far when you think back to FCP 3 and the jokes other vendors having.
