Dual Layer DVD?
Posted by Kevin Mccarthy on November 4, 2005 at 3:42 pmI’m trying to burn a dual layer 8.5 gig DVD. I have set the size limit in options. It has asked me where I would like the Break point etc. The problem is it only wants to allow me to auther a DVD It does not want to burn it. I have a dual layer burner everything seems to be as it should be. Any suggestions?
Thanks in advance
KevinMartin Healy replied 20 years, 5 months ago 5 Members · 9 Replies -
Gary Kleiner
November 4, 2005 at 3:50 pmAt what point are you hitting the problem? Any errors or warnings that need to be taken care of?
Gary
Kevin Mccarthy
November 4, 2005 at 6:10 pmI get a prompt to add a break point marker between to points on the video. How do you add a break point? I tried just adding a marker and calling it “Break point” on the timeline in DVDA but that doesn’t seem to work.
Donatello
November 4, 2005 at 6:22 pmeverytime DVDA has asked me about the break point it would list possible points (sometimes only 1 file , sometimes several files ) and i just click (highlight) on the file where i want the break point ..
Gary Kleiner
November 4, 2005 at 6:55 pmIt didn’t specify a time range where the break point had to be?
Gary
Kevin Mccarthy
November 4, 2005 at 8:18 pmYes, it specified a time range but I had a marker within that time range. I even added a marker and it still doesn’t recognize that it’s there within the suggested time range.
Kevin Mccarthy
November 4, 2005 at 8:56 pmIn my case there is only one file involved. DVDA (3.0c) tells me to place a marker between two points. when I do that DVDA doesn’t see the marker and keeps giving me the same message.
Edward Troxel
November 4, 2005 at 9:26 pm -
Kevin Mccarthy
November 4, 2005 at 9:37 pmI tried that – no luck. one other thing… I get the prompt, “the project size is to large for the selected media. Do you want to continue anyway?” I checked the settings and I’m set to 8.5 GB. My project size is 7.1GB. I don’t understand why I would be getting that message.
Martin Healy
March 14, 2006 at 7:07 pmHi there,
Did you ever get to the bottom of that dual layer problem?
The exact same thing is happening to me at the moment.
thanks,
Martin Healy
