Dual image importing – Vegas 12 Pro
Hi I’m a Vegas nube – so if you assume I know nothing you’re probably on the right track! I did do a forum search before posting but didn’t find anything that seemed to address my problem which is essentially this:
I want to import image sequences for a left eye and a right eye and get Vegas to display and render them in a stereo format.
The initial file format is png. I can bring them into the media library no sweat but I can’t find a way of telling the program to treat them as left and right eye of the same stereo image. Yes I have set the project properties for stereo images.
I then used a utility to combine my images into mpo files and used the dual streams option in Vegas on the import media requester. I selected top and bottom half as my display option in the image sequence media properties. (I also have top and bottom selected in my project properties. ) However, the result is that the program displays in preview the first stream in both top and bottom.
Anyone know what I might be doing wrong or perhaps direct me to a tutorial on the topic?
