Activity Forums Apple Final Cut Pro Legacy Dual display gone nuts
  • Dual display gone nuts
    Posted by Andy Hutchinson on April 30, 2005 at 2:56 pm
    A few weeks ago I changed my two CRT displays to 1280×1024 resolutions so that I could see more on my screens. I then decided to change them back to the less resolutions so my eyes wouldn’t have to strain so much and I am having problems with my left monitor when it starts up. I am not sure if the problem is the refresh rate or the resolution. I set the left display to 1024×768 with a refresh rate of 85 hertz and the right to 1024×768, 85 hertz. I have a kvm swith on the right monitor that is connected to my Mac and to a PC. It has been this way for over a year and never had any problems. Now when I have both monitors set to the Mac and I startup the left monitor goes whacko with the screen full of horizontal lines from bottom to top. I reset the P-ROM and it reset the left monitor but the right monitor had to be turned off. If I restarted with the dual monitors on the left monitor would go back to the horizontal lines again. I did find that if I turned the right monitor off and restarted the left monitor would start normally and then I had to turn the right monitor back on to the Mac.
    Is the refresh rate set correctly? Should it be 60, 75 or 96 hz?
    Andy Hutchinson
    Video Magic
    Winter Park, Fl
    OS-10.3.7, FCP4.5, SP 2.05, Dual 2.5 G5, 2 gigs RAM; Sys HD 200G : WD 200G 7200rpm with 8 Meg buffer; 2 WD 250G 7200 rpm with 8 Meg buffer FW enclosure; Lacie FW800 card; Maxtor 120G FW for storage, 1 WD,
    Steve Eisen replied 21 years, 4 months ago 3 Members · 2 Replies
  • Adam Schmidt
    April 30, 2005 at 7:31 pm
    I would switch the monitors to the opposite ports on the card and see if this fixes the issue.
    Adam
  • Steve Eisen
    April 30, 2005 at 8:30 pm
    refresh rate 60.
    G5 Dual 2.5 160GB System 400GB Media Drive ATI 9800 256MB 6 GB RAM
    Dual Gig Quicksilver 1GB RAM 80 GB System drive (3) 250 GB internal media storage
    15″ Al Powerbook 1.25 1GB RAM
    OS 10.3.8 FCP 4.5, DVDSP 2, QT 6.5, Boris Red 3GL 1.65 TB External Stor
