Activity › Forums › Adobe Premiere Pro › Dual Core Xeon Performance
Posted by Richard Milner on May 17, 2006 at 6:34 pmDoes anyone know if having a dual core xeon processor is equivilant to having two non dual core xeon processors?
Chris1621 replied 20 years, 3 months ago 7 Members · 11 Replies -
David Newman
May 17, 2006 at 9:02 pmThe Intel 955 and 965 are faster and less expensive to setup than Xeon. You should consider those.
– David Newman
– CTO, CineForm
– web: http://www.cineform.com
– blog: cineform.blogspot.com -
Peter Corbett
May 18, 2006 at 11:09 amIf you can wait, wait for the new Intel Duo chips in July. They will faster than any of them. But the new D960 dual-core 3.6 Intel is soooo tempting at the moment.
Peter Corbett
Powerhouse Productions
Australia
http://www.php.com.au -
Peter Corbett
May 18, 2006 at 10:34 pm -
Peter Corbett
May 19, 2006 at 4:52 amI decided to buy a D950 today to replace my D840. It’s a little slower at 3.4MHz but cheaper than the D965. I like to wait until new CPU’s, chipsets are out so the mobo manufacturers can release their higher-end stuff as well.
Peter Corbett
Australia
Chris1621
May 19, 2006 at 1:20 pmhello,
FWIW, I’m running on a AMD 4800+ Dual Core system and it rocks :-). It was also considerably cheaper than an Intel solution and the motherboard was specifically qualified for the BMD card which helped.
Albert Weissen
May 25, 2006 at 2:51 pmThanks, I’ve been looking for the best mobo to use with the AMD 4800. Did you run into any issues with it and PP 2.0?
