Activity Forums Adobe Premiere Pro DUAL core i7 CPU’s?
  • DUAL core i7 CPU’s?
    Posted by Paul Gale on December 16, 2009 at 9:58 am
    Anyone explored the use of DUAL i7 CPU’s on a server mainboard or something like the Asus Z8NA-D6 dual LGA1366 mainboard for Premiere/After Effects work?
    My main edit PC is a dual Xeon E5345 and I’m thinking of upgrading (yet again!) and going the lower cost i7 route.
    Paul Gale
    Silicon Pixel Ltd
    Jeff Brown replied 16 years, 9 months ago 2 Members · 3 Replies
  • Jeff Brown
    December 16, 2009 at 5:04 pm
    Paul,
    I’m not absolutely sure, but I believe if you’re talking about dual-processors, you’ll have to go with a new Xeon setup. The i7 chips are mostly the same as newer Xeons, but don’t have the CPU-to-CPU communications to enable use on a multi-processor system board.
    But unless you are doing a lot of truly multi-threaded rendering, you might be better with the fastest single i7 chip you can find. I recently added 2 new dual-Xeon (5500) machines built on a SuperMicro 1U rack server platform, and they don’t do all that much compared to my older (2 years) dual-Xeons, UNTIL I’m doing Mental Ray rendering, which maxes out all 16 cores per machine. Then they are quick like bunnies!
    -Jeff
  • Paul Gale
    December 17, 2009 at 8:19 am
    Mmmm, the newer top end Xeon’s (W5590) are very tempting – but very expensive. Which model CPU did you go for in those workstations?
    Paul Gale
    Silicon Pixel Ltd
  • Jeff Brown
    December 18, 2009 at 4:13 pm
    Hi Paul,
    Xeon E5520 Nehalem 2.26GHz LGA 1366 80W
    US$385 each at the time.
    Faster is better, of course, but there’s always a spot with Xeons where the price differential is, um, considerable. If you are rolling your own, do watch the power requirements for the Xeons; there are several power efficiencies made, you’re pwr supply/mobo will need to supply enough for the particular chips you purchase.
    -Jeff
