Activity Forums Adobe After Effects Expressions (Dual comps) Refer layer name to own comp name?
  • (Dual comps) Refer layer name to own comp name?
    Posted by Stanley Gucwa-bucasas on May 2, 2011 at 12:55 am
    x = comp(“DualComp”).layer(“Stan1”).transform.position[2];
    most of you know this links the z position of two layers that are located in separate comps.
    Layer “Stan1” is a composition nested in comp “DualComp”
    Within the “Stan1” comp, I applied the above expression to a layer.
    My question: because my comp name “Stan1”, becomes its layer name when I nest it in “DualComp”, is there a code i can replace “Stan1” with in the above expression?
    I want to be able to duplicate nested comp “Stan1” within “DualComp” and have the expression update accordingly.
    for example:
    x = comp(“DualComp”).layer(USE THE NAME OF THE COMP YOU ARE IN).transform.position[2];
    haha
    Thank you!
    Stanley Gucwa-bucasas replied 15 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 2, 2011 at 1:25 am
    Like this:
    x = comp(“DualComp”).layer(thisComp.name).transform.position[2];
    Dan
  • Stanley Gucwa-bucasas
    May 2, 2011 at 1:39 am
    should have known that!
    thanks again Dan, really appreciate it
