Activity › Forums › Apple Final Cut Pro Legacy › dual chroma wipe
  • dual chroma wipe
    Posted by Scott on September 28, 2005 at 10:07 am
    What is the easiest way to key a dual chroma wipe in FCP. The problem I am having is due to the incoming magenta and outgoing green both being visable during the wipe. I am new to FCP so all help would be appreciated.
    Cheers
    Scott
    Arnie Schlissel replied 21 years ago 3 Members · 3 Replies
  • Bouncing Account needs new email address
    September 28, 2005 at 1:08 pm
    Ii I understand what you’re asking…
    In the Effects Tab (above the Viewer Window)
    Adjust the keyer filter settings until the “color-leaks” are reduced or eliminated.
  • Scott
    September 28, 2005 at 3:44 pm
    Sorry Matte will try to explain myself better.
    I am using a graphic as a transition between pictures.
    Magenta is the colour of the background (outgoing video). The transitions begins revealing green (incoming video).
    Therfore I have to chroma key twice to get the effect to work.
    Do I have to nest the video after the first key and do a second pass?
    Cheers
    Scott
  • Arnie Schlissel
    September 28, 2005 at 4:10 pm
    In FCP, you can do this using the “Gradient Wipe” transition, but in your graphic the incoming section needs to be black, and your out going needs to be white.
    Arnie
    https://www.arniepix.com
