Activity Forums Apple Final Cut Pro Legacy Dual Boot Necessary for AVID/FCP system?
  • Dual Boot Necessary for AVID/FCP system?
    Posted by Dukenuk12 on November 9, 2007 at 9:45 pm
    I just got a macPRO here at my office and i am transferring all of my files from my old G5 which was a dual boot system for AVID and FCP on separate boot partitions. My questions is “Is this necessary? I can’t think of any reason why it shouldn’t work fine on a single partition but let me know your thoughts. I dont want to transfer an ungodly amount of data from one system to the other only to learn that i should have set up a separate partition before doing so. Thanks so much!
    David Parke
    Tim Wilson replied 18 years, 9 months ago 5 Members · 4 Replies
  • Walter Biscardi
    November 9, 2007 at 11:40 pm
    Dual boot is the way to go. The Avid codecs have caused issues with a lot of FCP systems in the past. Best to keep the two systems separated.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Alec Gitelman
    November 10, 2007 at 7:14 pm
    really? could that be the cause of my problem?
    i have a macbook pro which i use to run both FCP 5.1 and AVID XPress 5.7. While FCP is working quite well AVID is a bit sluggish, not responding to command clicks in real time (i’ve posted this issue on the AVID forums but did not get an answer).
  • Larry Asbell
    November 10, 2007 at 10:43 pm
    I have a dual boot system and it’s working fine:
    Quad G5, OS 10.4.9 or 10.4.10?, QT 7.2, FCP 6.01, MCSoft 2.7.3
    However I suspect it’s only a matter of time before I’ll want to upgrade the OS to a version that will help with FCP but won’t work with Avid. I figure I’ll go dual boot when I have to, but for now I don’t.
    – Larry Asbell
  • Tim Wilson
    November 25, 2007 at 6:26 am
    Sorry to get to this late. I hope the Duke is subscribed to this thread….
    I don’t have the latest version of FCP installed, but I had the one from two years ago running on the same machine with both Xpress Pro and Media Composer software for a living. I didn’t see any issues with them both open at the same time, either.
    Avid was a Mac-only company for its first ten years, and there are hundreds of them around in product management, design and engineering. I’m willing to wager that FCP was on 75% on them, and this is the first time I’ve heard anyone mention a dual boot system.
    I’ll test again when I get around to installing the new FCS (I know, I know, hardly new anymore), but I swear this is the first time I’ve ever heard of any issues.
