Activity › Forums › Panasonic Cameras › Dual Adapter question
Jeremy Garchow
April 2, 2009 at 4:24 pmCurious.
Are you logged in as administrator?
If so, just for yucks, try creating a new user that has admin privileges on your computer and see if it installs.
Luke Pearson
April 2, 2009 at 4:25 pmGood thought. I am logged in as the admin but I’ll give it a try.
Luke Pearson
http://www.LiftFilms.netDo not forget to entertain strangers, for by so doing some have unwittingly entertained angels.
-Hebrews 13:2 -
Luke Pearson
April 2, 2009 at 10:09 pmokay, that didn’t work. any other ideas?
Luke Pearson
-Hebrews 13:2 -
Jeremy Garchow
April 2, 2009 at 10:27 pmDid you try redownloading the drivers?
I am not sure why it’s not working.
Jeremy
Luke Pearson
April 2, 2009 at 10:51 pmI’ve tried to download them several times. When I try to go through the install process this is what it says,
“Install Failed! The following install step failed: run preflight script for P2(japanese letters). contact the software manufacturer for assistance.”
Luke Pearson
-Hebrews 13:2 -
Luke Pearson
April 3, 2009 at 2:15 amThat didn’t work either. Thanks so much for all your ideas. I know this is frustrating.
Luke Pearson
-Hebrews 13:2 -
Jeremy Garchow
April 3, 2009 at 4:19 amWell, I don’t know for sure. but this seems to be pointing to some sort of system error.
How aggressive are you willing to get? I have some suggestions, but we will be playing with fire and I don’t want to wipe your system out to unusable.
Do you have a clone of your hard drive?
Tom Brooks
April 6, 2009 at 12:48 amI have that computer and my Duel does not work correctly with it. The P2 drivers installed fine. I can use P2CMS to view the contents of P2 cards and folders. But ingest results in kernel panic. Same happens with Shotput P2. It’s the old familiar “Duel Adapter doesn’t work with some Macbook Pros” thing.
I have to use “Archive to Folder” from FCP Log and Transfer or just a straight finder copy to transfer files to hard drive. So far, that has been reliable, but it’s not the same a a copy and verify process.
Final Cut Pro 6.0.5, Mac OS-X 10.5.5, Quicktime 7.5.5, Adobe Prod Prem CS4, G5 Quad 2.5, Kona-LHe V6, 8.5GB RAM, Nvidia GeForce 7800-GT 256MB, G-RAID 2x1TB FW800, 6TB RAID-5 (Enhance E8-ML, Highpoint 2322), Panasonic HVX-200P P2. Also MBP 17″ Core 2 Duo 2.5, 4GB, GeForce 8600M GT 512MB.
