Activity › Forums › Apple Final Cut Pro Legacy › DSR-45: does it do both NTSC and PAL?
Posted by Ron James on November 2, 2006 at 8:27 pmCan anyone confirm for me (and I did a search for this, btw) whether or not the Sony DSR-45 DVCAM deck can record and playback both NTSC and PAL?
I’ll be using one purchased in Canada and would like to know if I’ll be able to do a PAL dub on it from FCP?
James
Steve Eisen replied 19 years, 11 months ago 5 Members · 8 Replies -
Steve Eisen
November 2, 2006 at 8:55 pmDSR-45A is NTSC ONLY
DSR-45AP is PAL ONLYThe DSR-11 does PAL and NTSC
Steve Eisen
Eisen Video Productions
Director-At-Large
Chicago Final Cut Pro Users Group -
Jeff Carpenter
November 2, 2006 at 9:05 pmI’m not sure exactly how you want to use the deck, but be aware if you get the DSR-11…it will record PAL from a PAL timeline or it will record NTSC from an NTSC timeline. It will NOT convert the video for you. If you’re trying to change it from one format to the other you need to get a plugin for Final Cut or a program that will convert it within the computer before you output it.
Steve
November 2, 2006 at 10:38 pmI have a DSR-45 and had to deal with a PAL issue awhile ago.
It plays Pal in your monitor window, but won’t export through firewire. I was able to capture through my AJA IO-LA, but I think only through the monitor out, which is the RCA plug.
It wasn’t a very important project, but it was kind of hack way of getting the video out.
Walter Biscardi
November 2, 2006 at 10:40 pm[steve] “It plays Pal in your monitor window, but won’t export through firewire. I was able to capture through my AJA IO-LA, but I think only through the monitor out, which is the RCA plug.”
Are you sure? The DSR-11 could play PAL video out via Firewire. Just had to flip that NTSC-PAL switch in the back, Power the deck Off / On, and then it was good to go.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Walter Biscardi
November 2, 2006 at 10:42 pm[walter biscardi] “steve] “It plays Pal in your monitor window, but won’t export through firewire. I was able to capture through my AJA IO-LA, but I think only through the monitor out, which is the RCA plug.”
Are you sure? The DSR-11 could play PAL video out via Firewire. Just had to flip that NTSC-PAL switch in the back, Power the deck Off / On, and then it was good to go.”
Nevermind, I see the answer is already posted up above. DSR-45 has two versions. Oh well, pay more, get less features!
Ron James
November 3, 2006 at 12:19 amThanks everyone,
I need to go from a PAL timeline to a DVCAM tape. I keep hearing that the DSR-40 and 45 decks can do this, thought it’s an unadvertised feature. I’ve never personally tried it, though.
This is a UK site, but I was just doing a quick search to provide an example. This FAQ mentions that “for DV, there are three of the Sony Professional DVCAM decks that can playback and record at SP speed on DV and miniDV tapes in both PAL and NTSC. These units are the DSR-11, DSR-25 and DSR-45.”
https://www.ee.surrey.ac.uk/Contrib/WorldTV/FAQ.html
I’ll have to try it out and see, I guess.
Ron James
November 3, 2006 at 3:25 amDang, it can playback PAL, but not record it. Crap. Just tried.
Jeff, a DSR-11 will definitely record PAL, though, from an FCP PAL timeline? I’ve got the conversion under control, just need something to dump to.
James
Steve Eisen
November 3, 2006 at 7:33 pmThe DSR-45A is a new version!
Bottom line, DSR-11 is what you want. Just remember, it does not convert PAL>NTSC. That you will need Nattress Plug-in (excellent plug-in Recommended Buy! You can’t beat the price on ALL his plug-ins) or use Compressor.
Steve Eisen
Director-At-Large
