Activity › Forums › Apple Final Cut Pro Legacy › DSR 1800 – FCP FW 400 – 800 connectivity problem
  • Rob Maloney
    May 18, 2010 at 4:55 pm
    Graham,
    Sorry to hear you are having the same problem I did. How I eventually solved the issue was to connect my FW400 cable out of the deck into a small, portable Lacie 160G drive, and then went FW800 out of the drive into the iMAC. So the drive acts like a router/converter. I don’t use it for anything else, but ever since I tried it, it has worked perfectly. The original problem seems to be on Sony’s end, but since the deck is EOL, they didn’t seem predisposed to come up with a software fix.
    Hope this helps.
    Rob
    “If you’re walking on thin ice, you might as well dance”
Page 2 of 2
