Activity › Forums › Adobe Premiere Pro › DSR-11 questions
DSR-11 questions
Posted by Lkj on September 29, 2005 at 8:42 pmI’m having some trouble getting a DSR-11 to record output of a rather long piece (95 minutes) to a DVCAM 184 minute tape. Repeated “camera failure” is the error message. Will the deck take a crash record (REC/PLAY) with the “activate recording device” checkbox off. Don’t know much about this deck. Just used for dv capture.
TIA
Lkj replied 20 years, 11 months ago 3 Members · 9 Replies -
Aanarav Sareen
September 30, 2005 at 3:05 amDo you have any way of previewing what is coming out from the DSR11? I have dumped over 2 hours of footage on DVCAM and have not faced a problem so far.
Aanarav Sareen
Adobe Certfied Expert, Premiere Pro
https://www.asvideoproductions.com/video -
Lkj
September 30, 2005 at 4:51 amHi and thanks for answering.
I went through the menus again. Can see bars and hear tone through the deck. But, machine control is still not kicking in after rendering the audio.
The deck sits unmoving. -
Lkj
September 30, 2005 at 6:49 pmThe DSR-11 does not move when I run Premiere. So I close it and open Sony Vegas. The deck works when running Vegas capture. Close Vegas, then I open Premiere and the deck responds. Problem with the firewire protocol requiring a reset? Peculiar.
Blast1
September 30, 2005 at 9:03 pmCheck your settings to make sure you are selecting the proper device control.
Aanarav Sareen
September 30, 2005 at 9:53 pmDo you have another program on your system that is capable of outputting to the DV Deck?
Aanarav Sareen
Blast1
October 2, 2005 at 8:57 pmIf your device control is set for Sony DSR-11, then something maybe corrupted, I use a dsr-11 and have no problems, you might try resetting the “Plug-in Cache file”(contains preferences) just start premierepro while holding down the shift key, just remmember any custom preference setting so you can replace them.
