Activity Forums Apple Final Cut Pro Legacy DSR-11 – jerky quality in the log and capture window
  • DSR-11 – jerky quality in the log and capture window
    Posted by Arnljot Bringedal on January 22, 2007 at 6:08 pm
    Asked about this earlier – but I messed up and explained my problem totally wrong – and therefore wasted everyones time.
    Sorry about that.
    Heres another go at it:
    In the log and capture window – playback a MiniDV tape (PAL) from my DSR-11 ( set to PAL )
    Audio/videosettings in FCP are all PAL.
    Still: the picture in the log and capture window – is extremly jerky – and has strange lines whenever something is moving in the picture.
    When I playback from a cheap canon camcorder – with all the same settings – the preview in log and capture window is fine.
    DSR-11 is brand new – and works like a charm in Imovie.
    Im sure there must be a setup – setting or something – wrong in FCP – but have no idea what it could be.
    *** Norwegian videojournalist & Editor***
    Andrew Kimery replied 19 years, 7 months ago 4 Members · 5 Replies
  • Captain Mench
    January 22, 2007 at 6:13 pm
    What’s the specs of the computer you are using?
    Try this too — Apple 1 until the viewer closes… Apple 2 until the canvis closes… Apple 3 until the timeline closes… then Apple 8 to open Log and Capture.
    Same issues?
    CaptM
  • Arnljot Bringedal
    January 22, 2007 at 6:34 pm
    MBP 17- 3 gigs ram.
    Tried all your tips – no joy…
    STATUS AS OF NOW:
    In the LOG AND CAPTURE window – playback from canon camcorder is fine
    BUT: playback from DSR-11 is so degraded that it is worthless.
  • Arnljot Bringedal
    January 22, 2007 at 6:35 pm
    sorry meant 2 gigs ram
  • Nathanh
    January 22, 2007 at 7:05 pm
    Hi Becker,
    I was just recently using the DSR-11 for capturing some PAL footage from a miniDV tape into FCP. I thought I had everything set up properly in FCP, but the capture still wasn’t working properly- video and audio in the capture preview were intermittent. I could see on the front of the deck that the light indicator switched to PAL when playing back the tape; so I thought the deck just auto-detected the source footage and everything would be fine. But it wasn’t until I switched the tiny little switch on the back of the DSR-11 from NTSC to PAL that everything worked smoothly. So if you haven’t already done that, then give this a try:
    Power down your Mac
    Power down the DSR-11
    Flip the switch on the back to PAL
    Then power up again.
    Hope this helps.
    Best,
    Nathan
  • Andrew Kimery
    January 22, 2007 at 7:37 pm
    I’ve used a number of decks & cameras on a number of FCP systems (everything from a 5yr old G4 to a new Intel Mac) and, as far as I can remember, the image shown in the Log & Capture Preview window has always been jerky and degraded. As long as the capture quality is fine I wouldn’t worry about it.
    -A
