Activity › Forums › Apple Final Cut Pro Legacy › DSR-11 heads access?
Posted by Michael Grabowski on November 21, 2007 at 3:43 amApologies for off-topic post, but most FCP editors seem to have experience with the DSR-11. After isolating dirty heads on a deck that the Sony Cleaning Cassette did not solve, I went to manually clean the heads with a head swab & cleaning solution. When I opened the case, I could not see any easy access to the heads. What gives? Anyone out there have a SOP, short of disassembling the entire deck or sending it out for service?
Many Thanks,
–MichaelEric Piercey replied 17 years, 9 months ago 6 Members · 9 Replies -
Paul Provost
November 21, 2007 at 5:13 amyeah kind of tough to get to the heads, possible though. these decks can be a little touchy. great product for the price, but if you can’t get it to work you’ll have to send it in. try playing another tape, recording and playing a tape etc. many times, it’s just a client tape that just won’t play…
Paul Provost
November 21, 2007 at 5:17 amalso try blowing out the insides with a can of air. last time I did this a half a dozen tiny strips of dv tape came blowing out! partially shredded masters over the years? this is a consumer format after all…
Rafael Amador
November 21, 2007 at 5:40 amThe DSR-11 is a nightmare for that. Tree times I’ve got a tape stuck inside, and the tree times I had to send it to Sony to extract the tape.
RafaelPPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17″Core2Duo 4GbRAM
JVC DTV-17″/FCS2/AE CS3/COMBUSTION/SHAKE -
Paul Provost
November 21, 2007 at 6:05 amsome dsr 11 decks are better than others. we have been very lucky with ours. maybe not very good quality control from sony?
Rennie Klymyk
November 21, 2007 at 7:39 amMine jammed a few times during tape loading when I 1st got it and I was able to remove the shroud and dig out the tape with no damage. After that I learned to always feed the tapes straight in and not let one side get in front of the other side. It hasn’t jammed for years this way. Full size tapes were the worst.
Be EXTREMELY careful cleaning heads with a cotton swab, they are very delicate and easy to damage.
Bill Carnicelli
November 21, 2007 at 1:44 pmMichael,
I clean the heads on my DSR11 all the time. Remove the top of the case. Looking down on the DSR11 you will see the tape loading mechanism. There are two small screws that hold it in place. Remove them and very gently fold the mechanism back. You will have access to the head now.
Bill Carnicelli
Carnicelli Media Productions -
Michael Grabowski
November 22, 2007 at 4:05 pmMany thanks to everyone for sharing their experiences, and thank you Bill for the tip. I had tried the four larger screws on top with no success, but had looked over the two smaller screws (it’s always the thing you don’t try, isn’t it?). If a delicate head cleaning fails me, off to Sony it goes!
Thanks again,
–Michael -
Eric Piercey
December 4, 2008 at 9:49 amWhat’s the best solution to use to do this, and what type of swaps? I think my heads are clogged. I’ve had to clean it every other time I use it lately and captures inconsistent.
https://hindsightproductions.org
Eric Piercey
December 22, 2008 at 12:37 amI found what I was looking for, chamois swabs and 99.9% Isopropyl.
https://www.parts-express.com/pe/showdetl.cfm?Partnumber=341-402
https://www.parts-express.com/pe/showdetl.cfm?Partnumber=341-518
https://www.partsexpress.com/pe/showdetl.cfm?PartNumber=341-362https://hindsightproductions.org
