Activity Forums DVD Authoring DSP Chapter points have audio/ video disturbance like layer break
  • DSP Chapter points have audio/ video disturbance like layer break
    Posted by Daisuke Kinouchi on March 13, 2010 at 2:58 am
    On DSP, I have created a dual layer DVD, SD, about7.9 GB. When I build or burn the DVD, all chapter points has audio/ video freeze for few frames like it does at the layer break point. There are 8 chapters in my DVD. I have never heard of this. What setting can I change to eliminate this problem?
    Eric Pautsch replied 16 years, 5 months ago 3 Members · 4 Replies
  • Michael Sacci
    March 13, 2010 at 3:08 am
    I would change the 3rd setting down.
  • Daisuke Kinouchi
    March 13, 2010 at 3:28 am
    Thank you for reply.
    Would you elaborate what you mean by 3rd setting down?
    Do you mean using Two-Pass VBR and Motion Estimate to Best?
  • Daisuke Kinouchi
    March 13, 2010 at 6:07 am
    I seem to have solved the problem by not linking the one chapter to another, meaning, in Connection window, for example, I had chapter 2 assigned when chapter 1 ends. I undid this and left it blank, and the problem went away. I’ve been doing this all this time and never seen the problem before. It must have something to do with the computer’s processing speed?
  • Eric Pautsch
    March 13, 2010 at 7:37 am
    Has nothing to do with the processing speed you just found your error. Never connect chapters…why would you author that way…just curious?
