Activity › Forums › DSLR Video › DSLRs and pyrotechnics
  • DSLRs and pyrotechnics
    Posted by Pete Burger on September 5, 2011 at 8:21 pm
    Does anyone has experience with shooting pyrotechnical effects with a DSLR?
    I was asked to shoot a music-video and the band wants to have some pyro effects in it.
    Should I expect problems with rolling shutter of the CMOS sensor?
    I’m asking, because when shooting concerts I’m always having trouble with strobe-lights.
    Any suggestions and/or advice is much appreciated! Thanks in advance!
    “Tragedy is a close-up; comedy, a long shot.” – Buster Keaton
    Pete Burger replied 15 years ago 4 Members · 8 Replies
  • 8 Replies
  • Noah Kadner
    September 5, 2011 at 9:15 pm
    Definitely shoot some tests- there’s rolling shutter to be concerned about and also of course basic safety issues that sometimes get lost if you’re talking low budget…
    Noah
    40% discount for Creative Cow users with code ccow2011 at Call Box Training.
    Featuring the Panasonic GH2 and GoPro HD Hero.
  • Phil Balsdon
    September 5, 2011 at 9:19 pm
    I don’t think you’ll have the same issues.
    The strobe light problem is caused by the lighting pulsing flashes of light that are faster than the shutter speed, therefore causing only the portion of the chip that was exposed during the pulse to be exposed.
    Pyrotechnics are constant burning sources of light with no pulse similar to tungsten, essentially just fire light.
    Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
    https://philming.com.au
    https://www.steadi-onfilms.com.au/
  • Pete Burger
    September 5, 2011 at 9:50 pm
    Thanks Noah! Safety (hopefully) shouldn’t be an issue. They’ve got a professional on set…
  • Pete Burger
    September 5, 2011 at 10:03 pm
    [Phil Balsdon] “The strobe light problem is caused by the lighting pulsing flashes of light that are faster than the shutter speed, therefore causing only the portion of the chip that was exposed during the pulse to be exposed.”
    Thanks, Phil! Yeah, that’s exactly the problem, I was worried about!
    I’ll talk to the pyro guy what he’s about to use.
    So we’ll better avoid fast flashing pyros and stick to more or less constantly burning stuff.
  • Chip Thome
    September 6, 2011 at 5:23 pm
    IMO, it shouldn’t be any different than shooting fireworks, which is basically what pyrotechnics are. If you can find the proper shutter speed for fireworks, I would think you should be good to go.
  • Phil Balsdon
    September 6, 2011 at 9:49 pm
    Even a fast flashing pyro won’t fade fast enough to cause a problem, with strobe we’re talking 1,000ths of second.
    I would however talk safety issues with the pyro guys. ie how close etc is still safe.
  • Pete Burger
    September 7, 2011 at 11:39 am
    Fireworks. Yeah, that’s the solution! Thanks a lot, Chip!
    I guess, that’ll be my starting point in research!
  • Pete Burger
    September 7, 2011 at 12:08 pm
    Thanks again, Phil!
    The pyro-guy does a lot of stage-effects and seems to be pretty experienced. But we will definitly have a “safety-meeting”, since neither the band nor the guys behind the camera(s) have worked with pyros before.
    So thank you guys for your input! Much appreciated!
